Hello Erik,
here, as promised, the photos...
In the first photo you can see the prepared crankshaft pulley on which the ring gear is then placed.
The optical sensor, which is supposed to detect the missing tooth on the ring gear, is then attached to the two bolts... (yellow arrows).
The parts will be assembled after typing and historical approval by the Austrian approval authority.
BR
Andreas
Zündspule Fiat Dino Spider (ohne Zündspule)
Re: Zündspule Fiat Dino Spider (ohne Zündspule)
Good evening Andreas
Sorry for the late feedback, and thank you for the pictures.
I have been looking at the same solution, but I thought it was a to thight space towards the oilfilter housing.
What is the outer diameter of your trigger wheel, or have you tested that it actually fits? BR
Erik
Erik
hello erik,
the inner diameter is 13,5 cm, the outer diameter is 14,5 cm.
There should be a distance of approx. 3-4 mm to the oil filter housing
Hi Andreas
I e-mailed the measurments you provided to Peter Klinger, but received this reply:
Are you sure that the inner diameter is 135 and the outer diameter is 145?
In this case the tooth depth would only be 2,5mm.
In case the inner diameter is 135 the outer diameter shall be 155mm
5mm are required for the tooth base and another 5mm for the tooth height.
Can you measure the required inner diameter since this is the relevant diameter?
The outer diameter is a consequence of the inner diameter.
Could you control measure the trigger wheel, and give me a feedback?
BR
Erik
BR
Erik
sorry...
I mistyped...
the inner diameter is 125 mm, the outer diameter is 145
I mistyped...
